Author Topic: PixInsight 1.8.3.1123 Ripley Released  (Read 11020 times)
« on: 2014 November 18 12:47:38 »
Hi all,
A new version of PixInsight has been just released and is now available to all users: 1.8.3.1123 for FreeBSD, Linux, Mac OS X (10.8 and later), and Windows.
Build 1123 is a maintenance release intended to stabilize the platform in preparation to important new modules and scripts that we plan to release during the next months. We encourage you to update all your installations as soon as possible.
How to Install the Release
This version is not available through the update system. You have to download the appropriate installation package(s) for your platform(s) from our Software Distribution system:
   https://pixinsight.com/dist/
Simply uninstall your current version and install the new one:
FreeBSD and Linux: PixInsight installation packages are gzip-compressed tar archives (.tar.gz). To install one of these archives, extract its full contents on any directory, preferably on one located under your home directory. Then become root and run the installer program from a terminal. For complete information on the PixInsight Linux/UNIX installer program, see this forum post:
   http://pixinsight.com/forum/index.php?topic=6336.0
Mac OS X: Uncompress the .zip archive on your /Applications folder. Starting from version 1.8.3, there are important changes in the way PixInsight is distributed on Mac OS X. Please see the following forum post for more information:
   http://pixinsight.com/forum/index.php?topic=7670.0
Windows: We provide standard Windows installation packages. To install one of these packages, first you must uninstall the version that you have currently installed. Then launch the package executable file and follow the instructions. Once installed, you'll have a new entry on your Start > All Programs menu (or equivalent item on Windows 8), namely PixInsight Platform, where you'll find an option to launch the PixInsight Core application.
Main Bug Fixes
This version fixes most confirmed bugs in the previous builds, plus a number of minor bugs and performance issues that we have discovered through exhaustive stress testing. Here is a partial list with the most important bug fixes:
* Core Application: Fixed several issues with projects generated by previous versions (1.8.2 and older).
* Core Application: Top-level windows were refusing to be resized programmatically to cover more than 2/3 of the screen height. This was causing many problems with large tool and script windows. This has been fixed so a window can now be resized arbitrarily from C++ (PCL) and JavaScript (PJSR) code, even beyond the available screen dimensions.
* Core Application: Fixed some screen flickering problems with tool windows on Windows 8.
* TIFF support module: TIFF files larger than 2 GiB could not be read/written on Windows. This regression has been fixed. See the original bug report:
   http://pixinsight.com/forum/index.php?topic=7765.0
Main New Features
This is a partial list with the most important new features in PixInsight Core 1.8.3.1123:
* New sealed projects feature. See this forum thread for more information:
   http://pixinsight.com/forum/index.php?topic=7768.0
* New FILE > Load Empty Project menu item. See the above forum link for more information.
* Improved project robustness. Projects are now much more tolerant to errors of many types. See the above forum link for more information.
* Improved project data storage management. Projects are now more efficient and robust to store data as inline blocks (in the XML project file) or external files (on the project data folder).
* All executables, modules and dynamic libraries (not just the core application) are now digitally signed with our corporate code signing certificates on Windows and Mac OS X. This is an important security improvement. However, please note that if your computer is infected by viruses and other malwares, altered signed files may prevent you from running PixInsight on your machine.
* View properties are now shown in real time on the View Explorer window. This is useful to inspect data properties associated with views, such as statistics, histograms and data generated dynamically by processes and scripts.
* Improved real-time generation of tree views on explorer windows, especially the View Explorer window.
I hope you enjoy this new release. Thank you for your continued support.
Offline geomcd1949
Re: PixInsight 1.8.3.1123 Ripley Released
« Reply #1 on: 2014 November 19 12:02:41 »
Probably a dumb question - how do I uninstall the previous version? I'm running Ubuntu Linux 14.04. Thanks!
« Reply #2 on: 2014 November 19 13:28:53 »
Just run the installer program as root. Type "yes" to install the new version. The installer will remove the previous PixInsight installation automatically.
Offline jyrki
« Reply #3 on: 2014 November 20 03:31:56 »
I just installed the new version after removing the previous one using Control Panel under windows 7. Now when I try to start the program a pop-up error messages says 'Authentication error. The server says: 'INVALID AUTHORIZATION CODE''. I am using a trial license and I'm new to PixInsight. Did I do something wrong?
« Reply #4 on: 2014 November 20 03:42:02 »
See FAQ 2.10 to reactivate your license: http://pixinsight.com/faq/
A trial license can only be used on a single machine at a given time. See FAQ 2.19 in case you want to move your license to a different machine.
Offline jyrki
« Reply #5 on: 2014 November 20 03:52:32 »
Yes, I have done that already (sorry for not mentioning this before) and I have received and e-mail with  the new activation codes. But I have no place where to put the right code for my OS, the software just quits after showing the error message. Is there any additional step I have to make?
Update:
Problem Solved!!! I went to the directory C:\Users\<user name> and renamed the file pixinsight-license to something else. Then it was just a matter of starting the program again and it asked for the user identifier and the activation code.
Thanks for the help!
« Last Edit: 2014 November 20 05:09:40 by jyrki »
« Reply #6 on: 2014 November 20 05:05:32 »
Hmm, that's strange. Please follow FAQ 2.23 to remove your trial license file, the run PixInsight and use your new activation codes. This should always work.
Offline jyrki
« Reply #7 on: 2014 November 20 05:16:16 »
That is just what I did, and I got the idea from the FAQ (didn't see your reply before that).
Now I'm back to get acquainted with this very nice software!
Thanks again!
Offline didou
« Reply #8 on: 2014 December 13 03:43:20 »
Sorry for my english ;)
I have some trouble to install new release.
I have got an error :
"Error opening file for writing :
D:\Astronomie\PixInsight\bin\Annotation-pxm.dll"
And it's same problem with others files.
I have three choise : abort, try again or ignored.
Could you help me please ;)
Must have install first old version of PI?
Offline didou
« Reply #9 on: 2014 December 13 13:00:18 »
I have found this topic and now it's ok
http://pixinsight.com/forum/index.php?topic=7771.0
sorry for my question ;)
Bye ;)
