Hello,
I am having some problems recently with saving images.
I have aligned the calibrated fits with drizzle data, then used image integration and drizzle integration as described on this forum to create a drizzle image. That image is generated without issues, and it looks good in STF. However, when I try to save it, I get the following error:
PCL Exception: PCL FITS Format Support: FITS file write error:
/path/drizzle_integration.fit
CFITSIO error message stack:
01 : Numerical overflow during type conversion while writing FITS data.
<* failed *>
This happens both under Windows 7 and Ubuntu 14, in Pixinsight 1.8.0 and 1.8.02 and 1.8.03. Also tried saving all fits formats: 32 bits, 8 bits, 64 bits, signed & unsigned etc, same result. Any suggestions?
I will also mention that calibration was done under Maxim not Pixinsight, however this shouldn't matter. I have tried stacking the same images without drizzle, and the result was saved successfully.
I appreciate any help with this, thank you
