Author Topic: ffmpeg - movies  (Read 3129 times)
Offline Jules
ffmpeg - movies
« on: 2014 October 31 06:11:47 »
I have recently seen an interesting object appear when I blink my recent images (not the target subject). I have been trying to make a movie from blink but I keep getting the error:
*** Failed to execute external process: Failed to start
Does this mean blink is looking for a program called ffmpeg, if I downloaded the program from the web, where would I need to install it.
Once I have made the movie I will post it as I am not sure what the object is. Its is moving relative to the other bright objects, I am convinced its not man made, perhaps an asteroid?
Julian
Offline rfrancis
Re: ffmpeg - movies
« Reply #1 on: 2016 April 16 14:51:02 »
I have this same problem.
I have this same problem. I'm running on MacOS X.
I have ffmpeg installed. If I run the same argument from the command line in a terminal window, it runs. If I use it in Blink, it comes au with the error message that the process failed to start.
I have tried replacing "ffmpeg" as the "program" with the full path to the executable, but still no joy.
Any help for us Mac users?
thanks,
Richard
Offline rfrancis
Re: ffmpeg - movies
« Reply #2 on: 2016 April 16 15:14:53 »
Problem solved: I was missing one directory name from the full path. Oops!
cheers,
Richard
Offline cardiofuse
Re: ffmpeg - movies
« Reply #3 on: 2017 January 08 08:28:14 »
What would be in the Blink "Argument" field?
Rick
cardiofuse observatory
Panama City
Re: ffmpeg - movies
« Reply #4 on: 2017 January 08 13:29:38 »
whatever arguments you want to pass to ffmpeg - video codec, bitrate, frame rate, etc. google "ffmpeg options" and you'll find a bunch of webpages describing how to configure ffmpeg.
