Thanks Steve!
I am not debarring... could that be the issue here? I'm noticed this in my CCD editing as well???
The images in question above are DSLR images. I am indeed referring to reg as registering and so forth... calibration and integration.
I am using a 60D with an Ha mod.
So you are basically creating an LRGB image form the data found in the color DSLR image?
I've not thought of that with DSLR in Pixinsight. I've been using it as a stack from the integration tool once I did the registration, calibration (with master flats and darks) and integration.
I'm also a bit confused on the way I capture flats... I've been taking around 20 flat frames before imaging with the CCD and Telescope pointed at the waning light of dusk... I expose these for 1 second each. Is this sufficient or should I do it another way?
Thanks for your response and help.
![smile :)](http://pixinsight.com/forum/Smileys/default/smile.gif)
