Author Topic: NGC 7331 & Quintet  (Read 2001 times)
Offline Robovet
    • robovet.net
NGC 7331 & Quintet
« on: 2014 October 26 11:59:33 »
I had trouble with light pollution gradients. Part of the problem was related to my east/west flats and rotator. Can anyone suggest a workflow to use the batch preprocess script ? I ended up just not using the subs from a meridian flip. I'm assuming you calibrate east and west separately and then use image integration to add the masters together ?
Large Version:
https://www.flickr.com/photos/94597165@N00/15631968561/in/photostream/lightbox/
Edge HD11 @ F7 Apogee U16 Lum 600 1x1 RGB 300 2x2
marc
Dr. Marc Laxineta
Equine Veterinary Medicine
Event Photography
www.robovet.net
951-378-1134  Cell
Offline Astrodoc
    • AstroDoc - Astrophotography by Ron Brecher
Re: NGC 7331 & Quintet
« Reply #1 on: 2014 October 26 18:33:43 »
Very nice!
Clear skies,
Ron
Offline Geoff
« Reply #2 on: 2014 October 27 03:25:44 »
I like the composition. Lots of nice detail in the quintet.  Loads of galaxies all over the field!  There does seem to be a problem--perhaps image tilt--in the top corners, especially the left corner with blue flares on the stars. The right hand top corner has a lesser version of the same problem, whereas the bottom corners are spot on.
Geoff
Don't panic! (Douglas Adams)
