Author Topic: The Moon Oct. 4/5  (Read 2311 times)
Offline Astrodoc
    • AstroDoc - Astrophotography by Ron Brecher
The Moon Oct. 4/5
« on: 2014 October 06 08:14:00 »
I couldn't figure out how to register images of the moon in PI (if someone can tell me, please do so! I am all ears).  However, I did all processing of the stacked image in PI.  In particular I found the RestorationFilter worked GREAT to recover detail in the image, LocalHistogramEqualization did a good job on the contrast and brightness and TGVDenoise was very effective for preserving detail during noise reduction.
Image and details at http://astrodoc.ca/gibbous-moon-october-4-2014/
Clear skies,
Ron
Clear skies,
Ron
Re: The Moon Oct. 4/5
« Reply #1 on: 2014 October 06 09:27:07 »
using the FFTRegistration script will probably work, it's worth a try anyway.
for certain lunar images i think people have had luck with StarAlignment, but the parameters have to be tweaked such that it can pick up bright features on the moon as "stars"
Offline Raymond
    • Astrophotography
« Reply #2 on: 2014 October 06 13:14:08 »
Hi Ron
You can use Staralignment; try following settings:
Star detection:
  scales: 8
  peak resp.: 0.90
  max. distortion: 0.050
I often get good results with those ones.
Following links may help you too (they helped me doing all the work in PI!):
http://pixinsight.com/forum/index.php?topic=5908.15
http://www.radice.biz/articoli/translations/71-creating-seamless-lunar-mosaics-in-pixinsight
Hope this helps
Raymond
Raymond
Planewave 14" CDK - 10Micron GM2000HPS
William Optics 110/770 & FF | HEQ5-Pro
Omegon 66/400 | MGEN-Lacerta
Canon 500d mod
Offline MikeOates
« Reply #3 on: 2014 October 16 07:25:41 »
Ron,
You may find a previous post of mine helpful, it includes Staralignment settings:
Processing Example: The Moon in NarrowBand using StarAlign & Drizzle
http://pixinsight.com/forum/index.php?topic=7214.msg48564#msg48564
Offline Astrodoc
« Reply #4 on: 2014 October 16 17:13:15 »
Thank you all for your suggestions, which I will look at as soon as I get the chance!
Clear skies,
Ron
Clear skies,
Ron
