this is maybe a stupid question, but are you sure this is is made without a flattener? It looks a little bit to good for me.
But nevertheless it looks like a tilt somewhere. You can try to rotate the Telescope in its clamps to test if the camera is to heavy for the focuser. When the oval stars are at the same position, the problem is most likely a general tilt. When the position changes, the focuser, or something else is too weak, or loose.
Greetings
Tobias
