www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Mosaic Star Alignment Settings
« previous
next »
Print
Pages: [
1
Author
Topic: Mosaic Star Alignment Settings (Read 3598 times)
Graham
PixInsight Enthusiast
on:
2014 February 26 01:06:54 »
Hi.
When creating mosaics, is there any settings I can change in Star Matching, Star Detection and Interpolation to help it solve the panels easier? Although I am working in a fairly heavy star field with what I feel is good overlap, it can sometimes take a long time to solve or even fails as it is not able to find good star matches. Sample of Processing Console attached.
Thanks in advance for any insights.
Graham.
Logged
Andres.Pozo
PTeam Member
PixInsight Padawan
Re: Mosaic Star Alignment Settings
Reply #1 on:
2014 February 26 01:43:12 »
I think that StarAlignment is detecting too many stars. You could try to increase the sensibility parameter to decrease the number of detected stars. The default value is -1. You could try with 0 or 0.5.
Also, if the images have noise you could set the "Noise reduction" parameter.
Logged
Gallery @ Astrobin
georg.viehoever
PTeam Member
PixInsight Jedi Master
Reply #2 on:
2014 February 26 06:34:36 »
- Is this a wide field? If yes, you may have run into the typical lens/projection distortion problem. Using the Image Solver family of scripts (
http://pixinsight.com/doc/scripts/ManualImageSolver/ManualImageSolver.html
as starting point) may help.
- sometimes it helps to place previews into the overlap regions, see
http://pixinsight.com/doc/tools/StarAlignment/StarAlignment.html#usage_011
Logged
Graham
Reply #3 on:
2014 February 27 00:41:41 »
Great, thanks guys, I'll look into it.
Yes, it will be a large area of sky. I am using an 8300 chip camera on a Tak TSA120 to create a 16 pane mosaic.
Logged
georg.viehoever
PTeam Member
Reply #4 on:
2014 February 27 08:09:02 »
At 900mm focal length you should not have problems with distortion resulting from projection. Dont know about lens distortion, but I think it is unlikely.
Logged
Graham
Reply #5 on:
2014 March 01 07:12:58 »
Hello Georg,
I'm not sure what could be affecting the mosaic process although I have not had time to read up and understand the other suggestions fully as yet. I am getting some time tonight to have a play and another problem has turned up. I seem to get a misalignment in one corner of the image. With 4 panels it was left bottom, with 6 panels it is top right. I have put in an image for you to see. I would appreciate any feedback from you or others.
I am following Steve Allan's tutorial on Gradient Merge Mosaics.
Thanks in advance.
Logged
georg.viehoever
PTeam Member
Reply #6 on:
2014 March 01 08:46:36 »
Did you play with the following StarAlignment Parameters:
- Registration Model=2D Surface splines. Gives more freedom in adapting star fieds than Projective Transformation
- Distortion Correction
- Be sure to read the StarAlignment docs
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
