<Texto en Español abajo>Hi all,
New versions of the PixInsight platform are now available to our users and can be downloaded from our server: PixInsight Core 1.1.5.387 and PCL 1.0.38.180.
These are mainly bug-fix releases. They fix several important problems that have been detected in the first 1.1 version of the PixInsight Core application. Please update your current installations as soon as possible.
***** Download Addresses
* For commercial users (user name and password required):
http://dist.pixinsight.com/* For users of 30-day trial licenses:
http://pixinsight.com/download/STD/IMPORTANT: Please take the following two points into account before installing a new version:
* Although not strictly necessary, it is advisable to uninstall the previous version that you have currently installed. On Windows, use the uninstall option from Start > All Programs > PixInsight Platform.
* You don't have to do anything with your PixInsight license file (.pixinsight-license on your personal folder) - of course, DO NOT delete it. Just install the new version, and all should work without problems.
***** Main Fixed Bugs
Most of the problems detected in the initial 1.1 version were affecting the new graphical interface of the core application. Among many other minor bugs, these are the most important errors that we have fixed in this version:
* The standard buttons (iconize, shade, normalize, close) for maximized windows were disappearing when these windows were deactivated. This has been fixed.
* The standard buttons used for maximized windows were too large (19x19 pixels). This was causing the main menu bar of the core application to be resized incorrectly when a window was maximized, mainly in the Windows version. Now these buttons are smaller (15x15 pixels) and no menu bar resize should occur.
* When a workspace containing maximized windows was destroyed, sometimes an access violation occurred which led to a crash of the core application. This has been fixed.
* When a workspace containing the Real Time Preview or ImageContainer interfaces was destroyed, an access violation occurred which led to a crash of the core application. Fixed.
* When several image windows were moved across workspaces, the target workspace could end with more than one active image window. Fixed.
* When a processing interface was launched from a process icon (for example, by double-clicking the icon), the interface was not moved to the current workspace. Fixed.
* When the real time preview mode was activated on a processing interface, the Real Time Preview interface was not moved to the current workspace. Fixed.
* Fixed a small memory leak that happened upon closing image windows.
In addition to the above ones, we have fixed two important problems detected in the ImageRegistration standard module and in the color management subsystem of the core application:
* The standard DynamicAlignment process was not assigning correctly the existing FITS header keywords, RGB working space, ICC profile, resolution parameters and metadata from the original images to the generated registered images. Fixed.
* When the "Ask what to do" policy was selected for untagged images (images not embedding an ICC profile) on the ColorManagementSetup interface, the default RGB profile was not available for assignment to untagged color images, but only the default grayscale profile. Fixed.
Along with these fixed problems, we have improved many aspects of the core application, especially many details of the new graphical interface.
We hope all of these changes will improve your experience with our software.
If you have suggestions or need help, don't hesitate to contact us at support@pixinsight.com, or at PixInsight Forum:
http://forum.pixinsight.com/Thank you for your continued support,
The PixInsight Team
Hola a todos
Nuevas versiones de la plataforma PixInsight están disponibles y pueden ser descargadas por nuestros usuarios: PixInsight Core 1.1.5.387 y PCL 1.0.38.180.
Se trata de versiones de corrección de errores, que solucionan varios problemas importantes que se han detectado en la primera edición de PixInsight 1.1. Es muy recomendable que actualice su instalación lo antes posible.
***** Direcciones de Descarga
* Para usuarios con licencia comercial (se requiere nombre de usuario y contraseña):
* Para usuarios de licencias de prueba (30-day Trial License):
IMPORTANTE: Por favor, tenga en cuenta los dos puntos siguientes antes de instalar una nueva versión:
* Aunque no es estrictamente necesario, es recomendable desinstalar la versión anterior que tenga instalada. En Windows, use la opción Uninstall desde Inicio > Todos los Programas > PixInsight Platform.
* No tiene que hacer nada con su archivo de licencia de PixInsight (.pixinsight-license en su carpeta personal) - por supuesto, NO lo borre. Simplemente, instale la nueva versión, y todo debería funcionar sin problemas.
***** Principales Errores Corregidos
La mayor parte de los errores que han sido detectados en la versión 1.1 inicial se producían en la nueva interfaz gráfica de la aplicación principal. Entre otros muchos errores de menor importancia, los principales problemas que han sido corregidos son los siguientes:
* Los botones estándar (iconizar, minimizar, normalizar, cerrar) correspondientes a las ventanas maximizadas desaparecían cuando éstas se desactivaban. Esto ha sido corregido.
* Los botones estándar utilizados para imágenes maximizadas eran excesivamente grandes (19x19 píxeles). Esto causaba cambios de tamaño inadecuados en la barra de menú de la aplicación principal en Windows. Ahora estos botones son más pequeños (15x15 píxeles) y ya no causan problemas.
* Al destruir un espacio de trabajo que contenía ventanas maximizadas se podía producir una violación de acceso que causaba la terminación inmediata de la aplicación principal. Corregido.
* Al destruir un espacio de trabajo que contenía la interfaz Real Time Preview, o la interfaz de ImageContainer, se producia una violación de acceso con terminación inmediata de la aplicación principal. Corregido.
* Al mover varias ventanas de imagen entre espacios de trabajo, el espacio destino podía contener más de una ventana de imagen activa. Corregido.
* Al lanzar una interfaz de procesamiento desde un icono (por ejemplo, haciendo doble clic sobre el mismo), la interfaz no se situaba en el espacio de trabajo actual. Corregido.
* Al activar la previsualización en tiempo real desde una interfaz de procesamiento, la interfaz Real Time Preview no se situaba en el espacio de trabajo actual. Corregido.
* Solucionada una pequeña pérdida de memoria producida al cerrar ventanas de imagen.
Adicionalmente, hemos solucionado dos problemas importantes detectados en el módulo ImageRegistration y en el subsistema de gestión del color de la aplicación principal:
* El proceso estándar DynamicAlignment no asignaba correctamente a las imágenes registradas las claves de cabecera FITS, el espacio de trabajo RGB, el perfil ICC, la resolución y los metadatos existentes en la imagen original. Corregido.
* Al activar la opción "Ask what to do" como política de gestión al abrir imágenes sin perfil ICC, no se daba la opción de asignar el perfil por defecto para imágenes RGB al abrir imágenes en color, sino sólo el perfil por defecto para imágenes en escala de grises. Solucionado.
Aparte de estos problemas y muchos otros de menor relevancia que han sido corregidos, hemos mejorado muchos aspectos de la aplicación principal, en especial muchos detalles en la nueva interfaz gráfica.
Esperamos que todos estos cambios contribuyan a mejorar su experiencia con nuestro software.
Si tiene cualquier sugerencia, o si necesita ayuda, no dude en contactar con nosotros en support@pixinsight.com, o en PixInsight Forum:
Muchas gracias por su apoyo,
El Equipo de PixInsight
