Author Topic: "All Registered Light Frames have been removed or cannot be accessed"???  (Read 4755 times)
Offline ftherrmann
Batch Preprocessing Script v1.33
PI V 1.08.00.1071 x64
Win 7 x64
I just uninstalled PI and removed the folder from the Programs folder and did a re-install.  Still getting the same error message.  It creates the registration folder but does not place the registered files into the folder.  Apparently when it tries to do the integration it can't find the registered files and bombs off with the "can not find or removed error".  I've tried a new script, but no luck.
any spaces or weird characters in your file hierarchy or sub exposure filenames?
Offline ftherrmann
no.  if there were I don't think the script would create the calibration and master folder along with the master flats.
so the calibrated images are there? you can put them into StarAlignment by hand (or maybe just a few of them) and see if SA can actually find any stars.
change the reference in SA to "file" and choose a random one, then load one different file into the target images and apply global. you can set the output directory to the right place in the BPP-created hierarchy if you like.
it could be that the registration failed and that's why there are no registered files.
-Have you unchecked "Calibrate only" on the Lights tab?
-Which files are there, and which are not?
-What is the exact error message you get in the Console Window? Simply paste the relevant Console output into a forum post.
Please dont post in this thread. Instead:
See http://pixinsight.com/forum/index.php?topic=6570.msg44521#msg44521 for more information on this issue.
