Hi Andy,
By "black and white profile", what do you mean exactly? Do you refer to a grayscale ICC profile?
Please select Edit > ColorManagementSetup, then click on Load Current Settings. Tell me which are your default color management settings.
I assume you have selected "Ask what to do" as the "On Missing Profile" policy. With that policy enabled, the Missing ICC Profile dialog opens when you open an untagged image (an image without an embedded ICC profile). This dialog provides three options:
* Assign the default profile - here you should see the default RGB profile that you have selected in ColorManagementSetup (or the default grayscale profile if the image is in the grayscale color space).
* Leave the image untagged. This is the default option. If you select this option, pixel values in the image are supposed to be expressed in the default RGB or grayscale profile, but no profile will be associated with the image explicitly.
* Disable color management for this image. Obviously you shouldn't select this option, unless you have a strong reason.
Also have into account that PixInsight, unlike other applications, has no problem to use RGB ICC profiles to manage grayscale images. In these cases, grayscale images are treated as RGB images with identical red, green and blue values for all pixels.
Does the above information help you? Or do you still think there's a bug here? I'd need some screen shots in order to understand where the problem is.
Thank you and keep bug reports coming
