Author Topic: PixInsight Not Preserving Original FITS Header Information  (Read 5301 times)
Offline twade
To PTeam,
I just noticed PixInsight is not preserving the original FITS header information.  For example, here's the original FITS header information:
SIMPLE     = T
BITPIX     = -32 /8 unsigned int, 16 & 32 int, -32 & -64 real
NAXIS      = 2 /number of axes
NAXIS1     = 4096 /fastest changing axis
NAXIS2     = 4096 /next to fastest changing axis
BSCALE     = 1.0000000000000000 /physical = BZERO + BSCALE*array_value
BZERO      = 0.00000000000000000 /physical = BZERO + BSCALE*array_value
OBJECT     = '        '
TELESCOP   = '        ' /          telescope used to acquire this image
INSTRUME   = 'Finger Lakes'
OBSERVER   = '        '
NOTES      = '        '
DATE-OBS   = '2008-04-03T06:13:33' /YYYY-MM-DDThh:mm:ss observation start, UT
EXPTIME    = 600.00000000000000 /Exposure time in seconds
EXPOSURE   = 600.00000000000000 /Exposure time in seconds
SET-TEMP   = -35.000000000000000 /CCD temperature setpoint in C
CCD-TEMP   = -35.062500000000000 /CCD temperature at start of exposure in C
XPIXSZ     = 9.0000000000000000 /Pixel Width in microns (after binning)
YPIXSZ     = 9.0000000000000000 /Pixel Height in microns (after binning)
XBINNING   = 1 /Binning factor in width
YBINNING   = 1 /Binning factor in height
XORGSUBF   = 0 /Subframe X position in binned pixels
YORGSUBF   = 0 /Subframe Y position in binned pixels
FILTER     = 'Lum     ' /          Filter used when taking image
IMAGETYP   = 'Light Frame' /       Type of image
OBJCTRA    = '12 34 14' /          Nominal Right Ascension of center of image
OBJCTDEC   = '+10 31 35' /         Nominal Declination of center of image
TRAKTIME   = 2.0000000000000000 /Exposure time used for autoguiding
FOCALLEN   = 0.00000000000000000 /Focal length of telescope in mm
APTDIA     = 0.00000000000000000 /Aperture diameter of telescope in mm
APTAREA    = 0.00000000000000000 /Aperture area of telescope in mm^2
SWCREATE   = 'MaxIm DL Version 4.61' /Name of software that created the image
SBSTDVER   = 'SBFITSEXT Version 1.0' /Version of SBFITSEXT standard in effect
FLIPSTAT   = '        '
SWOWNER    = 'Thomas W. Earle' /   Licensed owner of software
INPUTFMT   = 'FITS    ' /          Format of file from which image was read
SWMODIFY   = 'MaxIm DL Version 4.61' /Name of software that modified the image
HISTORY      Bias Subtraction (Bias 3, 4096 x 4096, Bin1 x 1, Temp -35C,
HISTORY      Exp Time 0ms)
CALSTAT    = 'BDF     '
HISTORY      Dark Subtraction (Dark 18, 4096 x 4096, Bin1 x 1, Temp -35C,
HISTORY      Exp Time 600s)
HISTORY      Flat Field (Flat FSQ (Lum) 02Apr08, 4096 x 4096, Bin1 x 1,
HISTORY      Temp -35C, Exp Time 1s)
PEDESTAL   = -100 /Correction to add for zero-based ADU
CSTRETCH   = 'Medium  ' /          Initial display stretch mode
CBLACK     = 6615 /Initial display black level in ADUs
CWHITE     = 8461 /Initial display white level in ADUs
Here's the FITS header after using DynamicAlignment and saving the file:
SIMPLE     = T / file does conform to FITS standard
BITPIX     = -32 / number of bits per data pixel
NAXIS      = 2 / number of data axes
NAXIS1     = 4096 / length of data axis 1
NAXIS2     = 4096 / length of data axis 2
EXTEND     = T / FITS dataset may contain extensions
COMMENT      FITS (Flexible Image Transport System) format is defined in 'Astronomy
COMMENT      and Astrophysics', volume 376, page 359; bibcode: 2001A&A...376..359H
PINSIGHT   = 'PCL 01.00.37.0178'  / PCL: PixInsight Core Class Library
COLORSPC   = 'Grayscale'          / PCL: Color space
RESOLUTN   = 72. / PCL: Resolution in pixels per resolution unit
RESOUNIT   = 'inch    '           / PCL: Resolution unit
ICCPROFL   = 'ICCProfile'         / PCL: File includes ICC profile extension
As you can see, all the original header has been destroyed.  Is there a setting in PixInsight to preserve this information?  I would highly recommend preserving the original data and just append PixInsight information to the header.
Wade
« Reply #1 on: 2008 April 09 00:48:00 »
Hi Wade,
This is in fact what happens when you open an existing FITS file and save it as a new FITS file. In this case, all (valid) original FITS keywords are always preserved.
However, when you generate a new image with DynamicAlignment, it doesn't inherit FITS keyword settings automatically from the original image. I agree with you that the original keywords should always be preserved in these cases.
Count on this problem fixed in the next version. In the meanwhile, a workaround is to assign the original keywords manually with the standard FITSHeader process:
- Ensure that the original image is the active image in PixInsight's workspace.
- Select File > FITS Header
- Drag an instance from the FITSHeader window to the registered image (the new image generated by DynamicAlignment). Optionally, you can create a process icon if you want to save the whole FITS header as a .psm file.
Thank you
Offline NKV
« Reply #2 on: 2008 December 11 00:34:37 »
Quote from: "Juan Conejero"
Hi Wade,
Hi Juan.
The problem not solved in 1.4.0 ver ?
Batch process erase important information in FITS Header.
Best regards,
Nikolay.
« Reply #3 on: 2008 December 11 01:22:14 »
Hi Nikolay,
Indeed. This is my fault - I just forgot to solve this problem in 1.4. Thank you for pointing it out.
Although my credibility has been certainly damaged :lol: I promise this will be fixed in 1.4.x.
