Author Topic: PixInsight 1.8.0 Ripley: Boosted STF AutoStretch  (Read 8322 times)
« on: 2013 December 07 13:14:19 »
The latest build 1065 of the PixInsight Core application introduces a new Boosted STF AutoStretch feature. Boosted STFs are like normal automatic screen stretch functions but more aggressive. They allow for more in depth inspection of raw data, and are also quite useful for visual inspection of special control images such as integration rejection maps.
For quick access to the boosted AutoStretch feature we now have a dedicated atomic tool button:
Note that the Ctrl+A (Cmd+A on Mac OS X) keyboard accelerator still invokes the normal autostretch feature, as usual. For now there is no accelerator assigned to boosted autostretch.
With default parameters, the difference between boosted and normal automatic STFs is considerable. The next screenshots show the difference for an HDR M42 image (courtesy of Vicent Peris and José Luis Lamadrid).
Normal STF AutoStretch
Boosted STF AutoStretch parameters can be configured. Open the ScreenTransferFunction tool and Ctrl-Click (Cmd-Click on Mac OS X) the atomic icon to the left of the window. This opens the STF AutoStretch dialog:
The boosted AutoStretch feature can be controlled with two parameters: boosted clipping factor and boosted background factor. These parameters are just multiplicative factors for the normal shadows clipping and target background parameters, respectively. The default values usually work well in most cases.
Another important difference in the latest version is that STF AutoStretch parameters are persistent across PixInsight Core sessions. The four parameters can be saved and retrieved by clicking the corresponding buttons on the dialog above.
Offline Josh Lake
Re: PixInsight 1.8.0 Ripley: Boosted STF AutoStretch
« Reply #1 on: 2013 December 07 20:45:40 »
Fantastic, can't wait to try!
« Last Edit: 2013 December 07 21:00:53 by Josh Lake »
Offline Lex
  • We do it at night...
« Reply #2 on: 2013 December 08 13:23:55 »
Hi Juan,
how is this update distributed; or how can I download it?
Thanks!
Clear Skies!!
Lex
« Reply #3 on: 2013 December 08 15:43:09 »
Hi Lex, you have to go to endor. On the right of the screen open "Workspaces" and select "Ripley release"
Saludos, Alejandro.
Offline Lex
« Reply #4 on: 2013 December 09 22:18:50 »
Hi Alejandro,
thank you very much, yet another thing learned  O0
Clear Skies!!
Lex
Offline Graham
« Reply #5 on: 2013 December 14 07:01:18 »
I have lost my login for endor so I can download this as I would like to give it a whirl on some data that I have.
How can I recover this?
Graham. :)
« Reply #6 on: 2013 December 14 13:49:01 »
Hi Graham,
If you did not change it, your password should be the same you use for download from the distribution site (http://dist.pixinsight.com/).
Anyway for request a new one: https://pixinsight.com/contact/index.html
Saludos. Alejandro.
Offline Graham
« Reply #7 on: 2013 December 14 15:17:01 »
You guys are always on the ball! Thank you for your wonderful help.  :D :D
