Author Topic: Adding Scripts  (Read 2690 times)
Offline Graham
Adding Scripts
« on: 2013 December 07 02:42:09 »
Hello.
I was unable to find an answer using the search function, so I was wondering if someone can tell me how to add a script to PI so I don't have to use the Execute Script function and search for it when I want to use it.
Can I add it to a particular category or does it go in a generic listing.
Thanks in advance,
Graham.  :)
Offline mschuster
Re: Adding Scripts
« Reply #1 on: 2013 December 07 20:35:18 »
To add a script to the menu, choose Scripts > Feature Scripts... > Add. Select the folder contain the script.
You can just search for it in the menu, or alternatively open the script in the editor and look for the "#feature-id" line. This line gives its location.
« Last Edit: 2013 December 07 20:45:24 by mschuster »
Offline Graham
Re: Adding Scripts
« Reply #2 on: 2013 December 08 00:30:47 »
Thank you for your help. Worked a treat :)
