I'm opening CR2 file like usual, do an STF to check it out, run NoiseEvaluation script, all fine.
Lunch Debayer process, using default settings apply it to the same CR2 file. Do an STF, all looks good.
Now try to run Noise Evaluation script and got this:
* Channel #0
** Warning: No convergence in MRS noise evaluation routine - using k-sigma noise estimate.
?R = 0.000e+000, N = 1 (100.00%), J = 1
* Channel #1
?G = 0.000e+000, N = 1 (100.00%), J = 1
* Channel #2
?B = 0.000e+000, N = 1 (100.00%), J = 1
If I run this same file through the BatchDebayer, then load to PI, the Noise Evaluation script works fine.
