On a relatively normal-looking image of M33, DBE is failing with:
"This DynamicBackgroundExtraction instance has less than three background samples defined."
I have tried the suggestions found on other posts:
1. Increasing the Tolerance. I bumped it all the way to to its maximum of 10.
2. Increase Shadows relaxation.
For some reason, every sample point appears red in the sample viewer and so the Wg and Wb are 0.000 for every point, regardless of what I set the Tolerance to. However, the actual G and B pixel values are NOT zero; they seem to be normal values.
Can someone help me understand what's wrong with this image? DBE works fine on other images.
