Author Topic: Question about HaRGB mosaics  (Read 2701 times)
Offline Phil Leigh
« on: 2013 October 16 07:19:21 »
I am in the midst of a multi-panel mosaic of the Heart and Soul nebulae. So far I have 4 connected RGB frames and will need a 5th & 6th.
I intend to augment the RGB frames with Ha.
My question is; what is the best assembly sequence or does it not matter? - should I create HaRGB panels and then union them OR do I create 2 complete mosiacs (RGB and Ha) then merge them?
thanks
Phil
Re: Question about HaRGB mosaics
« Reply #1 on: 2013 October 16 08:50:12 »
probably more foolproof to stack up each frame into HaRGB and then do the mosaic merge.
in theory if you have a good reference image to register all the panes to, making a mosaic of each channel separately should come out okay. but there could be minute differences in the registration of each channel's mosaic, especially if there is enough distortion in each pane.
Offline Phil Leigh
« Reply #2 on: 2013 October 17 01:29:40 »
Thanks Rob - that makes perfect sense!
Offline Tom OD
« Reply #3 on: 2013 October 17 01:53:42 »
So far I have 10 pane mosaic of LRGB by making an RGB layer and a separate L layer for each pane. It does work that way. I have not tried L, R,G, and B as a separate layer though. Seems both methods should work. You need good flat data, and equally good colour balance on the RGB frames though.
Tom
