Author Topic: CR2 raw files and batch preprocessing script  (Read 3382 times)
Offline astrodoc71
« on: 2013 September 29 16:22:13 »
When I try to load the CR2 raw files into the batch preprocessing  I get the error "unable to determine frame type" . CLearly they load into the PI main window with  no problem.
Dave
Offline astrodoc71
Re: CR2 raw files and batch preprocessing script
« Reply #1 on: 2013 October 11 16:27:49 »
You have to make sure to to select "add lights" or whatever file type it is because there is no header info. You can't just click on "add files"
As in another post, converting the raw files to fits using batch conversion makes the script run smoother
