Hello all, I am currently evaluating PI in the hopes that I can get better results than PS that I have been using till now. And so far it is very promising. With PS I usually only do some stretching with maybe an artificial flat via guassian blur to remove vignetting etc.
I tried PI on two stacks (all files at:
https://www.dropbox.com/sh/9vvf00mls5bxr3n/4K4YVc7yYa , Both stacks done in DSS using auto adaptive weighted average, RGB channels background calibration and alignment of RGB channels in the final image)
- On Crescent I did the following: STF to aid in cropping, HistogramTransform to bring out details, HDRWaveletTransform, ACDNR, AutoHistogram
- On Cocoon I did the following: STF to aid in cropping, HistogramTransform to bring out details, ATrousWaveletTransform with noise reduce, AutoHistogram
Would like to hear from you if the workflow above looks good and if the final result looks good. I am sure you can achieve a better result from the same raw stack, I would like to see the processing result and also your workflow.
thanks,
Manoj
