Author Topic: Red "D" descriptor on process icons disappears on SCRIPT icons  (Read 4220 times)
Offline Philippe B.
    • CIEL AUSTRAL
Hi Juan
I optimize my Preprocessing PROCESS ICONS with newest options of ImageIntegration and StarAlignment and I wanted to put some HELP to each Process Icon for all the users in France to better understand what I selected
I can do DESCRIPTORS for all of them except for the SCRIPT icons ! (I didn't tested all)
Do the following task (only tested on WIN7 64bits) :
With an image on desktop, open a script  (for example DRAW SIGNATURE)
drag (if possible) blue triangle to the desktop
write something in the right bottom small "D", it becomes RED
Save the processicon
Erase it
Load it
The RED D disappears but the text is still on the editor
I don't use the SCRIPT icons by launching it but it is just to have information like NOP icons (but as it is to launch a script, I prefere this)
Is it possible to get a fix ? :-[
Re: Red "D" descriptor on process icons disappears on SCRIPT icons
« Reply #1 on: 2013 September 17 05:23:19 »
Hi Philippe,
Bug confirmed. It happens with Script icons on all platforms. I'll try to release a bug fix as soon as possible, thank you for reporting.
Note that when I fix this bug your .xpsm and project files will remain valid. The problem is in the Script process (which is internal to the core application), not in the XML files (fortunately...!).
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #2 on: 2013 November 21 02:52:12 »
Hi Juan
Not corrected on preview 1.8.0 ?  :-[
I got the same problem
« Reply #3 on: 2013 November 21 03:29:14 »
You're right, I forgot to include this bug fix - unforgivable on my part.
This bug is now fixed. The new version that I'm going to upload this afternoon doesn't have this problem. Thanks for being alert ;)
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #4 on: 2013 November 21 04:29:25 »
you are the Best  ;)
thanksssss !!!
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #5 on: 2013 December 09 02:17:19 »
Hi Juan
with 1065, I cannot edit anymore the text in any process icon. When I click on the arrow EDIT, window closes  :sad:
Good luck !
« Reply #6 on: 2013 December 09 04:07:54 »
Hi Philippe,
http://pixinsight.com/forum/index.php?topic=6418.msg43714#msg43714
This is now fixed in the final release. I can't believe how this little red D thing can cause so much trouble. Sometimes less is really more!  :D
You can edit icon information by right clicking and selecting "Edit instance information".
