Selecting reference image for integration.
If all images are identical – it doesn’t matter, but let us assume that I have a series of images taken with different exposure times, ISOs, or F-stops
I was just wandering if selecting different references for integration will produce different results.
By default, integration uses the first image from the list, but there is an option to select a particular reference image.
When a reference image is selected, it sets its “weights” values to a “1”, and the other images’ weights are set accordingly.
So, which image should we select? Shorter, or longer exposure, higher, or lower ISO, which of them would be the best reference? Or, does it matter?
Thnx ....
