Author Topic: ImageIntegration on calibrated vs uncalibrated images takes 20x longer. Why?  (Read 2793 times)
Offline balt
Hi all,
I was just creating a master dark and accidentally ran it on the debayered frames instead of the debayered and calibrated ones. I then noticed that running ImageIntegration for a dark takes many times longer when run on the calibrated frames. Why is that? I thought the calibrated frames just have a bias frame applied to them, so the end result should be no more or less calculation intensive? Options used:
Average, no normalisation, iterative k-sigma scale estimator.
Cheers
- Balt
Offline papaf
Uhm, why are you creating a master dark from debayered images? They should still be bayered...
On the behaviour, I think the less noise there is, the longer it takes the windsorized sigma algo to run. If you use black images, for example, it would take forever.
Offline balt
Hi, that's what I was suspecting. Not enough noise! And yes of course that should not be done on the debayered images. Thanks for pointing this out!
Cheers
- Balt
