Author Topic: combining Lrgb when binned differently  (Read 3112 times)
Offline andyo
« on: 2013 September 07 09:57:23 »
Hi I am going to be combining binned images in PI for the first time and wanted to just check that Pi resizes the images automatically for combination so if anyone can confirm this that would be great.Previously with unbinned images I calibrate and register using the script batch preprocessing tool and then integrate using the integration tool.The RGB channels I combine with the channel combination tool and after processing I finaly use the LRGB combination tool to add the lum.Is this the same for images where the L is 1x1 and the rgb 2x2 or do I need to resize the RGB before combining with the L.If anyone can help with this that would be great thanks
Re: combining Lrgb when binned differently
« Reply #1 on: 2013 September 07 10:03:31 »
yes StarAlignment will resize your target image to match the dimensions of the reference image.
Offline andyo
« Reply #2 on: 2013 September 08 07:44:27 »
