I should probably post this from home since I can reproduce it there and actually report the exact error text.
I am trying to stack 8 120 second frames of M31, but I'm getting "Noise evaluation problems" and something about channel 0 (zero) while attempting I believe to stack the images from the Batch Processing script.
I noticed it was failing when working with the very first image from the lights so I removed that image and tried again. Same thing with the very next image.
I brought all the images into DSS and it stacked them fine. I'm not exactly sure what the issue is as I'm quite new to this.
Does anyone have any insight (pun not intended) on how to resolve this issue? I definitely prefer the outcome of PixInsight's stacking over DSS.
If more info is required, I will post it later tonight when I get home.
Dave
