Lo all,
I have a question about blending images of different exposure timings. I have several sets of sub-frames of M42 from my canon 350D taken at different exposure timings and I would like to merge them all together to create one finished image. I have all of the calibration frames for each of the different sets of varying exposure timings so I can calibrate each of the different timed sets separately, do the cosmetic corrections, then it would be going to registration. So here are many questions, yes there are more than just one question.
1.) Once each different set of subframes has been calibrated should the registration be done separately? Just wondering due to the how the star alignment functions the difference in the star illumination of the different exposure timings would affect star alignment matching up stars.
2.) If the registration is done separately what would be the best way to align the resulting integrations of each set? Same issue of varying star illuminations if stack is left as a linear image.
3.) Now about the actual integration of each set. I'm thinking pixel math should be used to perform the final stacking of the resulting integrations from each of the different timing set frame integrations. My exposure timings are a set of 10 second, 30 second, 60 second, 120 second, & 180 second frames. Likely do a percentile ratio of merging the frames together? These would be RGB OSC frames to be merged, any help or suggestions? I have never performed as series of different timing to one final image before with PIxInsight any help would be greatly appreciated. On a side note these images are from 2009 I attempted to do this in PS CS4 Extended, but the result was less than satisfactory, it has been my one and only such attempt prior to this. I was hoping I could achieve better results with PixInsight using PI's better deeper processing capabilities! Here is the original attempt from those exposures using the PS CS4 Extended.
http://www.thestardeckobservatory.com/Star_Deck_Albums/main.php/v/TheStarDeck/CanonXTAstrophotos/Nebulae/M42_012209_Composite.jpg.htmlThanks,
Mark Jordan
