Author Topic: New to PI and very confused  (Read 5505 times)
Offline cbobchin
« on: 2013 August 18 14:20:41 »
All,
I've got the trial version of PI and am trying to process an image of M16 I took a couple of weeks ago. It was captured with Nebulosity and I'm not happy with the results I'm getting from it.
I've watched Harry's videos several times and while I can follow along, I don't get the same results. I've posted the raw files along with my stacked version from nebulosity up on my Dropbox public folder: https://www.dropbox.com/sh/grlvcfopgepspt1/dShr_o5xnH
The Darks and Flats are in the M16zip file and the bias is in the Bias.zip file.
If someone can take a look at these and let me know what I'm doing wrong I'd appreciate it.
I tried using the preprocessing script as in harry's calibration video but I wind up with a lot if individual frames and not one master image. I'm not sure how to stack and combine them into one image.
I also tried processing a stacked image from nebulosity and got nowhere fast.
I really wish there was a manual that laid out the basic workflow that I could read, but alas there isn't.
Thanks in advance.
Offline vpcirc
Re: New to PI and very confused
« Reply #1 on: 2013 August 18 15:13:54 »
Look at Warren Keller's Pixinsight series on IP4AP.COM. It will take you from setting up your PI desktop to all the processing steps to the intermediate level.
Offline cbobchin
« Reply #2 on: 2013 August 18 18:14:57 »
Thanks. I looked at the free ones and they look very similar to what Harry has. But a bit more complete. I have to give serious thought to buying the video series to supplement an already expensive program (providing I do in fact buy PI).
astropixel
  • Guest
« Reply #3 on: 2013 August 18 20:11:47 »
When you select an output folder, a master folder is created. Is there no master folder? The master files are in there.
DSLR, I presume? RAW files.
Were your master files calibrated/processed in any way in nebulosity, prior to importing them to the batch processing script?
Do you have a set of untouched raw files to use with the batch preprocessing script? That is straight out of the camera? Try those first.
With a little guidance, I'm sure that you don't need to purchase how to videos to evaluate PI.
Using untouched raw frames and using the batch preprocessing defaults for now,
Load your frames by tab - Bias, Dark, Flat, Light
Select a reference image from your light raw frames
Select an output directory
"Run" - diagnostics will alert you about any fundamental errors to this point.
Coffee, tea...
When all done your linear integrated image is found in the master folder of the output directory.
Hope this answers some of your questions
Offline vpcirc
« Reply #4 on: 2013 August 19 04:14:50 »
I'm sure spending $49 on tutorials is a killer! The PI user interface is not intuitive by any means. I would of dumped it before buying it without Warren's tutorials. It's an outstanding program, but for a beginning imager without experience with any complex software, it's not easy to understand.
Offline Harry page
« Reply #5 on: 2013 August 19 12:22:52 »
I had no problem using the script just chucked it all in and got the usual master frames ?
Regards
Harry
Harry Page
Offline Harry page
« Reply #6 on: 2013 August 19 12:48:07 »
Did a very basic process
DBE-histogram stretch-acdnr-star reduction with morph trans-LHE and a little saturation added at the end
Pi handles your data very easily I promise
Harry
Harry Page
Offline cbobchin
« Reply #7 on: 2013 August 19 21:18:30 »
Harry
Harry, That's amazing. May I ask you to share the workflow and various settings  that you used to do this?  I want to try and learn by following the examples.
Offline Harry page
« Reply #8 on: 2013 August 20 09:26:03 »
Will do , but cannot sort anything out till tomorrow  :-[
Harry
Harry Page
Offline cbobchin
« Reply #9 on: 2013 August 20 16:30:19 »
Harry
Thanks Harry, Can you please send me/post a full sized image of shot you processed?
Offline cbobchin
« Reply #10 on: 2013 August 20 17:09:37 »
Coffee, tea...
Rowland, that does answer some questions. But I'm using an SBIG ST8300c not a DSLR, though they are both OSCs.
The drop box links I posted has the unprocessed FITS.
I was expecting the calibrated/stacked image to open automatically after the processing was complete.
Once I knew where to look I was able to find it. Thanks,.
astropixel
  • Guest
« Reply #11 on: 2013 August 21 00:31:54 »
It would be nice if BPS presented the finished image once complete.
Offline Harry page
« Reply #12 on: 2013 August 21 13:08:51 »
See here for a small video :)
http://www.harrysastroshed.com/Temp.html
All basic stuff , but might help   8)
Regards
Harry
Harry Page
astropixel
  • Guest
« Reply #13 on: 2013 August 21 15:40:23 »
You will need to select a different Bayer/colour matrix in BPS debayer options for your 8300 - BGGR, I recall.
Offline cbobchin
« Reply #14 on: 2013 August 21 18:20:41 »
Regards
Harry
Thanks Harry. The Video is very helpful. I'll be using it regularly. Can you please add a link the final FITS file as well?
