Author Topic: Linear Fit  (Read 3592 times)
Offline Dimitris Platis
Linear Fit
« on: 2013 August 16 03:18:39 »
Could someone explain to me why it is common practice (or maybe not) to use Linear Fit in cases of narrowband imaging in order to align the Luminances of Ha/OIII/SII before RGB channel combination?
Shouldnt the relative strength of each channel be presented as is and isnt that a better representation of the actual conditions?
Dimitris
Re: Linear Fit
« Reply #1 on: 2013 August 16 03:44:53 »
I guess it's used just as an "easy" way to equalize the three narrowband images. Using LinearFit is in this case as arbitrary as any other tool such as  HistogramTransformation, curves, etc., but more automatic.
Not necessarily. It depends on what you want to communicate with the image. For example, in galaxy images mixing Ha data with broadband RGB data the Ha image has to be amplified if one wants to represent HII regions; otherwise Ha and red are usually indistinguishable. In this case, by boosting Ha we are increasing the information represented in the final image. This is plausible as long as we apply uniform criteria to the whole image, based on physical properties of the objects, and as long as we inform the spectator that we have applied these techniques. Here is an example with M51.
Re: Linear Fit
« Reply #2 on: 2013 August 17 03:27:07 »
I understand..it makes sense.
Thanks Juan...
Do you believe that it is more correct to combine RGB channels before or after stretching (in narrowband cases or even perhaps in LRGB)?
