Author Topic: Save As File Generation Name Bug  (Read 4252 times)
Offline twade
« on: 2008 February 01 12:33:18 »
PTeam,
While attempting to save the file using the Save As... option, I get the following behavior:
Original file name,
m45_165mm.fit
After clicking on the "Files of type:" drop-down list  and selecting TIFF files in the Save Image File As dialog, I get the following result in the File name: edit box,
T:\Images\M45\165mmm45_165mm.tif
The automatically generated "file name" should be,
T:\Images\M45\165mm\m45_165mm.tif
For some reason, PixInsight Standard v01.00.55.0367 is  "forgetting" to add the last back-slash separating the directory portion from the actual file name.
Wade
« Reply #1 on: 2008 February 03 11:43:28 »
Hi Wade
This has been reported a few days ago too with other formats... we think that it is a Window's issue, due a problem with the Qt libraries. This may take a while to correct, since it involves to modify external source code, wait a fix, or modify our code to use native Window's dialogs (and that option is the less preferable, since we want to keep our code fully cross platform).
