Author Topic: Batch format conversion Error  (Read 4141 times)
Offline JirkaB
« on: 2013 July 28 02:27:59 »
Trying a new version of PI 1.8 RC7 and I have a problem with the script "Batch format conversion".
When converting images using this script will always be an error, see attached picture:
Other scripts are OK.
What am I doing wrong?
Re: Batch format conversion Error
« Reply #1 on: 2013 July 28 03:32:08 »
If this is reproducible, you should make the file available to juan. This should not happen.
« Reply #2 on: 2013 July 29 02:30:35 »
Indeed this should not happen. To understand and fix this problem, I need a file where it can be reproduced.
Offline JirkaB
« Reply #3 on: 2013 July 29 17:09:05 »
I uploaded some test images to  http://files.uloziste.com/ce6ad9530831ddfc/test.zip
I need convert some sets of FITS 32/64 float to TIF16, or TIF16 to FITS 32 float.
PC configuration is Win7 Pro 64bit, Intel Core i5, 16GB RAM, PI 1.8 RC7, all updates.
JirkaB
« Reply #4 on: 2013 July 30 04:00:21 »
Hi JirkaB,
Bug confirmed. It happens on all platforms, and is related to ICC profiles. I'm working to get this sorted out as soon as possible. Thank you for the images.
Update: I have found and fixed this bug. It requires a core application update, which I'll try to release later today. Sorry for the inconvenience.
« Last Edit: 2013 July 30 04:17:19 by Juan Conejero »
« Reply #5 on: 2013 July 30 13:33:14 »
This problem is now fixed with the latest updates to the PixInsight Core application (build 1023) and the BatchFormatConversion script (v 1.3.1).
Offline JirkaB
« Reply #6 on: 2013 July 30 16:07:01 »
conversion now works correctly. Thanks for perfect job.
