Author Topic: HistogrammTransfrmation produce error  (Read 4722 times)
Offline drknoppi
« on: 2013 June 28 04:41:14 »
Hello ,
I am Rainer and i try to start working with PI , but  if i tried to streched a linear lum-image to nonlinear and after i choosed the right image
in HT , a violent exception occured ??? I don`t know whats wrong here .
I hope you have  a good idea . ;)
See attachment
Best regards
Rainer
Re: HistogrammTransfrmation produce error
« Reply #1 on: 2013 June 28 05:03:33 »
Is that repeatable? Which OS? Anything special in your image? Can you share your image file (e.g. dropbox)?
Offline drknoppi
« Reply #2 on: 2013 June 28 05:24:05 »
Hello Georg,
yes its repeatable also with non - linear images  >:D, i work under MAC OS X 10.8.4, 8 Gbyte RAM/ 512 SSD.
It seems to be an error while selecting/reading an  image in HistogrammTransformation version PI  -   1.8 .
Best regards and thank you for the quick answer .
Rainer
« Reply #3 on: 2013 June 28 09:59:12 »
Never saw that on Win7 or Linux. Maybe MacOS specific, or specific for your image.
« Reply #4 on: 2013 June 28 10:21:57 »
if you still have it open, i would save the project, quit PI and then reload the project. after an issue like this PI can sometimes just completely crash and you can lose all your work (unless you want to go through the pain of trying to restore your .swp file)
Offline drknoppi
« Reply #5 on: 2013 June 28 13:13:19 »
Hello Georg,
after saving all important files. i reconstruct the complete project,
i found that my Lum file from the old project was wrong, that
why pi crashed every time while i  used histrogrammtransormation  >:D
Thanks for your help
Rainer
« Reply #6 on: 2013 June 28 14:25:31 »
so it is a corrupt .fits file? maybe you can send it to juan - it's kind of a bad thing when a program crashes due to file parsing issues.
Offline drknoppi
« Reply #7 on: 2013 July 01 00:46:50 »
Hello,
 i tried again to load lum and h - alpha image
inside a new ! project . And no problems select and show images
within histogrammtransormation  ;) The problem must be inside the old project ?? but not inside the image !
I am lucky within the new project i can`t find any problems, but what was the reason ?
I found another problem after loading  f.e. red calibrated image in a new project
and after STF automatic i found wave like image structures, why ?
Best regards
Rainer
« Reply #8 on: 2013 July 01 10:19:10 »
This could be a problem of posterization. First thing to try, is to copy the STF to an HistogramTransformation, apply it to the image, and see if the "waves" are there. If not, it was a problem of the STF's limited dynamic range.
If the problem continues, then it may be a problem in the calibration/processing... so, we should know which steps did you follow.
Offline edd
« Reply #9 on: 2013 July 01 13:39:30 »
Looks like CCD fringing to me, which would need the construction of a superflat to remove?
Offline Conor
« Reply #10 on: 2013 July 10 16:02:03 »
Looks like the kind of artifacts you'd see applying a stretch to a lossy format, like JFIF, to me.
Can you upload example data somewhere?
Takahashi FSQ 106 EDX III w/ QE Reducer
William Optics 110FLT Apo Triplet
William Optics Megrez 72 Apo Doublet
iOptron CEM60
QSI 583ws & 3nm Ha/OIII/SII filters
SBIG ST-i
Trying to use PixInsight on FreeBSD
