Author Topic: Preprocessing and bias causing lines on the image  (Read 4364 times)
Offline swag72
« on: 2013 June 03 03:02:31 »
Here's something that I don't understand in my preprocessing stage, I've attached an image of the problem. I am pre processing using just lights and bias at this stage and when I use the bias frames I get lines down the image. When I preprocess without bias and just use the image integration tool the lines disappear.
Is there a setting that I am using incorrectly with the bias frames? Both the bias and light frames are captured in Maxim.
I hope someone can help as I do want to use bias frames, but at the moment it's better without them.
Re: Preprocessing and bias causing lines on the image
« Reply #1 on: 2013 June 03 07:42:28 »
is it a dslr, and how many bias frames did you use? if it is a dslr you may need 100s of bias frames due to banding issues.
Offline swag72
« Reply #2 on: 2013 June 03 12:37:25 »
No it's a CCD - Atik 460EX mono and I used 25 bias frames and 11x1800s lights.
Offline Andres.Pozo
« Reply #3 on: 2013 June 03 12:41:51 »
How did you calibrate the images? Did you use BatchPreproccess? Did you create the Master Bias with PI or Maxim?
Offline swag72
« Reply #4 on: 2013 June 03 13:09:26 »
I calibrated the images in the PI BatchPreprocess script, so the master bias was created in PI. I only use Maxim for capture, nothing else.
« Reply #5 on: 2013 June 03 15:37:18 »
i don't know about that camera, but i routinely use 200 bias frames and 100+ darks with my 8300M... i have a lot of cloudy nights to take darks.
Offline jerryyyyy
    • Astrobin Images
« Reply #6 on: 2013 June 04 14:02:43 »
Can I ask a question in here?  Do you really need 100+ darks?  I though the value decreased with the square root of the number.
Also I assume PI can process images that are say 600s with darks collected at 1800s.  It does not go in the other direction does it?  Calibrate 3600s images with 1800s darks?
« Last Edit: 2013 June 04 15:09:27 by jerryyyyy »
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline Andres.Pozo
« Reply #7 on: 2013 June 04 15:07:47 »
http://pixinsight.com/forum/index.php?topic=4112.msg28652#msg28652
Offline gvanhau
« Reply #8 on: 2013 June 06 08:48:00 »
Hello
Have you tried to calibrate manually using the indicidual proceses?
I have so far never used the batch processing script, instead I do all calibration using the individual processing May be I'm wrong, but I feel I have more control doing so.
In this case it should be something like:
first Integrate bias there is a tutorial here for settings http://www.pixinsight.com/tutorials/master-frames/en.html
Next step is calibrate lights
Then align
finally integrate.
I have a Atik 450 (similar) and had no problems with it.
Regards
Geert
Geert Vanhauwaert
Offline sreilly
« Reply #9 on: 2013 June 08 16:25:04 »
I guess it's important to know if you are scaling your darks? Or are you using darks of the same temperature and time? If you aren't scaling the darks then I don't think you need the bias frames. I may be wrong but I seldom use bias frames to calibrate my ST10XME or STL-11000M cameras.
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline swag72
« Reply #10 on: 2013 June 09 10:55:04 »
I don't use darks, and up antil now the bias has worked well. I have integrated the subs without the bias and the lines have disappeared, so it's something to do with the bias.
I may have a look at doing it manually - Thanks for the tip.
