Author Topic: Process Functions....  (Read 3057 times)
Offline Parag Mahajani
  • Educator (Professional) and Astronomer (Amateur)
« on: 2013 May 04 05:34:57 »
Hello..
I am new to PixInsight and have installed Trial Version 1.7 Just one quick question...Is the Evaluation version 1.7 is complete application with all the functions? I am unable to find Histogram Transformation as well as Screen Transfer Function. Actually I am trying to use the application for review.
Please advise...
MILKYWAY CITIZENS PRIVATE OBSERVATORY, PUNE, INDIA
0.3 meters reflector, 60 mm H-Alpha,
Canon 50 mm, 200 mm, 75-300 mm, Tokina Fish-Eye, Sigma 10-20 mm and Sigma 600 mm Prime Lenses
Canon 60D Mod and Canon 550D DSLR
Televue Eyepieces,
Re: Process Functions....
« Reply #1 on: 2013 May 04 05:45:03 »
Yes. It should be the full program. The trial is just time limited.
At the startup, check that the IntensityTransforms module has been installed. If not, check that the library is in the bin folder. Then, try to install it from the main menu, processes, manage, install.
« Reply #2 on: 2013 May 05 06:27:50 »
Thank you for your reply....Yes,  I have in /home/parag/Downloads/bin/ the IntensityTransformations-pxm.so library.
I run the PixInsight application from LXTerminal of lubuntu with the following command: parag@localhost:~/Downloads/bin$ ./PixInsight.sh
Once the application is opened, then I can't see the process in the "Process Explorer" of the application.
But below the "Process" menu, I can see Intensity Transformations with only two options: DigitalDevelopment and LocalHistogramEqualization.
 Pl. advise.
Many Thanks.
Televue Eyepieces,
« Reply #3 on: 2013 May 05 07:24:16 »
Try reseting the program. Launch PI with the control key pressed down, and a window will appear asking confirmation for this.
« Reply #4 on: 2013 May 05 08:54:44 »
No luck. Visible only two processes after reseting: DigitalDevelopment and LocalHistogramEqualization.
I have also received a mail regarding the new release 1.8.0 RC7 Ripley. Should I install it? But can I use the existing User Identifier and Activation code?
Pl. advise.
Thank you.
Televue Eyepieces,
« Reply #5 on: 2013 May 05 09:29:09 »
You have to copy the created licence file. The activation code works only once.
See http://www.pixinsight.com/faq/index.html  for more details.
Maybe the file containing the module was corrupted. Try RC7, and see if that solves the issue. Anyway, I encourage you to use that version, since it is the most advanced and stable release up to date.
