I've tried using the same procedure to defect correct using the defect map and image container as I did with 1.7. Latest version 1.8 processes one image, then stops responding and crashes. Here's what I do:
open an image container, add the files I want to correct, iconize it.
open the defect map image file and the defect correction tool, select the defect image
drag the defect correction triangle over the iconized image container.
I do recall some of the correction options not working right in 1.7 (also crashed) but at least one of the options always worked. Anybody know what's going on?
