Hi Simon,
I have prepared a small tutorial on process containers and process icons to help you and others understand how these important things work in PixInsight.
To create a new process container, open the ProcessContainer interface from the Process Explorer window. Then you can simply drag existing process icons to add them to the process container:
You can create a process icon with the process container instance that you have defined in the usual way. Click on the
New Instance icon of ProcessContainer (the small triangular button) and drag it to the workspace:
Once you have created a new icon, you can rename it by clicking on its tiny
Rename button (or from the icon context menu by right-clicking on the icon):
You can also edit the
instance information associated with the icon:
Once you have defined the instance information, it can be viewed by clicking the icon's
View Info button. Note that this button changes to red color when there is some information defined for the icon.
You can drag other process icons to ProcessContainer to add them to the existing set of instances. When you drop the icon, a copy of its instance is inserted below the drop target:
You can also move instances in ProcessContainer. This allows you to reorder the set of instances:
By dragging the New Instance button to an existing process icon, you can replace it with the current instance of ProcessContainer. This operation cannot be undone (a dialog box opens to request confirmation):
Finally, you can drag an existing ProcessContainer icon to the ProcessContainer interface's control bar to replace the current set of processes:
Hope this helps.
