Author Topic: Update Problem of RC3 under VMWare Win8  (Read 4261 times)
Offline Lex
  • We do it at night...
« on: 2013 February 06 12:05:46 »
Hi everybody,
I am no longer able to updt PI under VMware Win8 environment ? I am getting the attached Error Msg?
Since I am not very familiar with Win8, I can not isolate the origin of the problem..
Any Ideas?
BTW.: this doesn't mean that it's a bug; not necessary  >:D
Thanks!
Clear Skies!!
Lex
Re: Update Problem of RC3 under VMWare Win8
« Reply #1 on: 2013 February 11 01:25:48 »
Hi Lex,
From the screenshot, this looks like a folder permissions problem. We use Windows on VMware virtual machines all the time, and have never seen this problem. Can you try on a physical machine? On a different user account? Somebody else can confirm this issue?
Offline Lex
« Reply #2 on: 2013 February 11 09:57:22 »
Hi Juan,
I already thought the same but appearently nothing changed in the permissions. The sharing options did not change, I think so...
The problem showed up after the upgrade so the native windows 7 wasn't touched to deeply.
Thing I did not try is to reinstall PI completely.
Sadly I do not have a physical Win8 machine and as I am the admin on the Virtual Machine I do not think that this originates the problem.
I will give it a try by reinstalling and keep you posted if the problem persists..
Thanks Juan!
Clear Skies!!
Lex
Offline Lex
« Reply #3 on: 2013 February 12 11:59:44 »
I uninstalled RC3 and reinstalled it. The program as usual told that there were updates available; and I got the same error message than last time?
I installed the 64bit Win version and the errors message says something related to 32bit?
I can not figure out what this could be?
Clear Skies!!
Lex
Offline Lex
« Reply #4 on: 2013 February 12 12:06:28 »
On the other hand the path of the error message does not exist, it does the match with the "real" disk structure?!  ???
Clear Skies!!
Lex
« Reply #5 on: 2013 February 12 13:22:03 »
The AppData directory may be hidden?!? Maybe it contains a version of the file from a previous update that it cannot delete.
Offline Lex
« Reply #6 on: 2013 February 13 12:12:11 »
Georg,
this may be a solution, I'll give it a try  :D
thanks for the input!!
Best
Clear Skies!!
Lex
Offline Lex
« Reply #7 on: 2013 February 14 12:38:02 »
Good evening friends,
just found the folder in question that is proclamed not beeing empty...
Unfortunately it is empty? What now?
Best
Clear Skies!!
Lex
Offline Lex
« Reply #8 on: 2013 February 14 12:53:37 »
Guys;
problem solved. I tried to empty the different folders of the folder doc without succes.
I then simply moved the doc folder; and see there, RC3 update without any error message?
Kind of strange; isn't it?
Best
Clear Skies!!
Lex
