Author Topic: [1.8RC1]: Unable to load library icui18n  (Read 12557 times)
« on: 2012 December 28 11:07:30 »
On Fedora17 when starting (we already saw this is one of the earlier versions):
code]$ PixInsight.sh
Unable to load library icui18n "Cannot load library icui18n: (icui18n: cannot open shared object file: No such file or directory)"
PixInsight Core 01.08.00.0932 RC1 Ripley (x86_64)
Copyright (c) 2003-2012 Pleiades Astrophoto
PI nevertheless works...
Re: [1.8RC1]: Unable to load library icui18n
« Reply #1 on: 2012 December 29 03:05:32 »
But not optimally. You should install libicu on your distribution. On Fedora (and other RPM-based distros):
$ su -c 'yum install libicu'
« Reply #2 on: 2012 December 29 04:42:49 »
In my opinion you should package libicu with PI to be sure that you get the exact version that you would like to see. Also PI should work on standard installs of the supported Linux distros without requiring additional installs.
When I try to install libicu on Fedora17, I get this:
Password:
Loaded plugins: langpacks, presto, refresh-packagekit
updates/17/x86_64/metalink                               |  18 kB     00:00
updates                                                  | 4.7 kB     00:00
updates/primary_db                                       | 7.3 MB     00:13
updates/group_gz                                         | 439 kB     00:00
Package libicu-4.8.1.1-4.fc17.x86_64 already installed and latest version
Nothing to do
Checking with "ls" shows it is actually there:
$ ls /usr/lib64/libicui18*
/usr/lib64/libicui18n.so.48  /usr/lib64/libicui18n.so.48.1.1
So apparently the lib is there, put PI does not pick it up (presumably it is looking for some other version).
Offline slang
« Reply #3 on: 2012 December 29 05:59:55 »
I get a similar erro with Ubuntu 12.04.
dpkg -L libicu48
/usr
/usr/share
/usr/share/doc
/usr/share/doc/libicu48
/usr/share/doc/libicu48/copyright
/usr/share/doc/libicu48/NEWS.Debian.gz
/usr/share/doc/libicu48/changelog.Debian.gz
/usr/share/lintian
/usr/share/lintian/overrides
/usr/share/lintian/overrides/libicu48
/usr/lib
/usr/lib/libiculx.so.48.1.1
/usr/lib/libicudata.so.48.1.1
/usr/lib/libicuio.so.48.1.1
/usr/lib/libicutest.so.48.1.1
/usr/lib/libicule.so.48.1.1
/usr/lib/libicui18n.so.48.1.1
/usr/lib/libicutu.so.48.1.1
/usr/lib/libicuuc.so.48.1.1
steve@svr3:~$ ls -al /usr/lib/libicui18n.so
lrwxrwxrwx 1 root root 20 Jan 26  2012 /usr/lib/libicui18n.so -> libicui18n.so.48.1.1
steve@svr3:~$ ls -al /usr/lib/libicui18n.so.48.1.1
-rw-r--r-- 1 root root 1866528 Jan 26  2012 /usr/lib/libicui18n.so.48.1.1
and
sudo apt-get install libicu48
Reading package lists... Done
Building dependency tree
Reading state information... Done
libicu48 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
shows it as being the latest version.
Mounts: Orion Atlas 10 eq-g, Explore Scientific G11-PMC8
Scopes: GSO RC8, Astrophysics CCDT67, ES FCD100-80, TSFLAT2
Guiding: ST80/QHY OAG/QHY5L-II-M
Cameras: Canon EOS 450D (IR Mod), QHY8L, QHY163m/QHYFW2-US/Astronomik LRGBHaSiiOii
