Author Topic: Batch preprocessing errors  (Read 3837 times)
Offline mwilliams
« on: 2012 December 20 04:59:22 »
Hello, I have been trying to use the Batch Preprocessing script,  (per Harry's
video) but always get the error "cannot integrate less than three frames", despite the fact that
I have "Calibrate Only" checked.  Even when I go ahead and select integration parameters, it
still tells me "cannot integrate less than three frames".  No matter what I do.  (I have ten
frames selected.)
It seems this tool is heavily weighted toward integration and registration, as opposed to
calibration.  Integration and registration are fantastic tools in PI, whereas I have never
successfully calibrated an image in PI when using the older algorithm.  Does anyone else
use the Batch Preprocessing script?  Thanks for any help.      matt
Offline kwiechen
Re: Batch preprocessing errors
« Reply #1 on: 2012 December 20 05:11:14 »
Do you have selected enough bias/dark/flat frames or did you select master frames generated with the bpp script?
Kai
Offline jdonald
« Reply #2 on: 2012 December 20 05:40:16 »
Same issue.. I have never gotten that script to work with my CR2 files, tried debayering, I get some weird error at the end and it never finishes and I followed the tutorial, I gave up and am using DSS now :(
Offline mwilliams
« Reply #3 on: 2012 December 20 06:01:46 »
Hello Kai, you are the script author.  Thank you for your offer to help.
I select Bias and Dark master frames, and have tried selecting both individual
flat frame and a master flat options.  However the master frames were
created in CCDStack, and saved in 32 bit floating point.  I did not use
PI to create any of the masters.
Matt
Offline Geoff
« Reply #4 on: 2012 December 20 11:26:03 »
I strongly suspect that creating master frames in CCDStack is the problem. I could never consistently import fits files from CCDStack into PixInsight.
Geoff
Don't panic! (Douglas Adams)
Offline kwiechen
« Reply #5 on: 2012 December 20 11:37:25 »
Please try to generate the master frames in PI.
Kai
Offline mwilliams
« Reply #6 on: 2012 December 23 05:35:52 »
I obtained all the requisite master files in Pixinsight, and the Batch Preprocessing Script worked!
For some reason, it wouldn't accept my master flat (even though I had master file checked), so
I just used my individual flats.  Anyway, thanks for your help.       Matt
Offline Josh Lake
« Reply #7 on: 2012 December 23 07:07:33 »
Great! Once you get everything working, I think you'll find BPP to be an incredibly useful and powerful script to start every processing run with. I'm so grateful for it (Kai!).
