Author Topic: Combining subs of differing FR and exposures  (Read 2518 times)
Offline Terry Danks
« on: 2012 October 20 08:12:15 »
Hi All:
I am faced with combining data consisting of different exposure lengths (5min and 20 min) as well as exposures at f/4.0 and f/2.8 through the same camera lens.
I plan on processing each variant separately with matching flats and darks and then combining them with the Integration Tool.
There is a problem though. In cases where I have only two variants, e.g., 5min@f/2.8 and 5min@f4.0, the Integration Tool will not work as it requires a minimum of three images.
Is there a solution to this? Or a better way of combining disparate data entirely?
Re: Combining subs of differing FR and exposures
« Reply #1 on: 2012 October 20 09:57:48 »
probably you should use HDRComposition, if your idea is to recover blown highlights in the longer/faster exposure.
otherwise you can just calibrate all the images, register them, and stack them all together with ImageIntegration.
Offline Ioannis Ioannou
« Reply #2 on: 2012 October 20 12:09:15 »
Integration Tool requires three images, but does not prevent you to add the same image(s) twice  ;)
Clear Skies
John (Ioannis)
FSQ106N+Robofocus+QHY-22+SX USB wheel+Baader filters
SX OAG+DSI Pro guiding a NEQ6
PI for the rest :)
