Author Topic: PJSR installing and viewing a script .pidoc?  (Read 4038 times)
Offline mschuster
« on: 2012 October 11 13:02:51 »
My script is installed in the menu via Feature Scripts... and my .pidoc is installed by the compiler in the proper PXI_DOCDIR doc/scripts directory.
But when I try to view the doc via accessing the Process Explorer <Scripts> section I get a Script documentation not available message.
What else should I do to install the doc? I looked in the pidoc and compiler docs but don't see anything.
Update: The script editor's compile pidocument command is broken on Win7. An error appears in the console. Running the compiler from the script menu works fine.
Update: I found the .pidoc install problem - a typo on my part. The Win7 command problem remains however.
« Last Edit: 2012 November 12 12:32:04 by mschuster »
