For sure, temperature has its importance as a CCD has a different response (noise, uniformity, linearity, noise pattern, cosmetic defaults) when temp is changing.
Bias and dark MUST be at the same temperature than images
Flat can have different temperature but in this case it will be necessary to do bias at same temp to correct the flat.
Ok, if you have 5-10 deg C difference, it is not a problem. But if ther is more, you will need to be more correction.
