www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Problem with MMT and dark pixels
« previous
next »
Print
Pages: [
1
Author
Topic: Problem with MMT and dark pixels (Read 3784 times)
DanielF
Member
on:
2012 September 18 12:46:19 »
Hi.
I'm trying to do some noise reduction with the MultiScaleMedianTransform module but I'm getting some strange results.
My image has a lot of noise and after applying MMT some darker pixel are unaffected by the processing and it doesn't look so good.
I've used a clone of the image as a mask for the high signal areas.
I have attached images showing my image (a preview) before and after applying MMT, and the MMT-settings.
Anybody that has any idea what I'm doing wrong or if the problem is due to bad integration or something else?
Regards
Daniel
Logged
NGC7789
PixInsight Old Hand
Re: Problem with MMT and dark pixels
Reply #1 on:
2012 September 18 13:02:01 »
I'm still a newbie but I believe the "adaptive" control takes care of this.
Logged
DanielF
Member
Reply #2 on:
2012 September 18 13:34:26 »
Quote from: NGC7789 on 2012 September 18 13:02:01
Thanks! I actually tried different settings on the adaptive control but I apparently used too low values. It got better when I cranked it up a bit...
Logged
topboxman
PixInsight Addict
Reply #3 on:
2012 September 18 13:49:09 »
I use the same MMT settings as yours plus I add to Layer 4:
t = 0.5 and s = 0.66
Try that and see if that helps.
I use MMT with pretty good results. I also clone the image and apply as an inverse mask.
Peter
Logged
marekc
PixInsight Addict
Reply #4 on:
2012 September 18 13:59:47 »
I think the recommendations to play with the `Adaptive' settings may be correct. I managed to eliminate some dark blobs after MMT processing, by playing with the Adaptive settings:
http://photonshotnoise.blogspot.com/2012/07/making-adaptive-progress-with.html
- Marek
Logged
topboxman
PixInsight Addict
Reply #5 on:
2012 September 18 14:18:13 »
Very interesting. I will have to try that. Are there any negative side effects?
Peter
Logged
marekc
PixInsight Addict
Reply #6 on:
2012 September 18 21:03:05 »
I didn't see any obvious side-effects. In the case of the Virgo image I was processing, I found that the right Adaptive settings managed to get rid of the `dark blobs'. If this created any new artifacts, I didn't notice them.
Logged
topboxman
PixInsight Addict
Reply #7 on:
2012 September 19 07:16:02 »
I tried this method last night. I noticed a small side effect. It seems to over smooth the image. It connects stars that are close together and draws white lines in between stars only if the stars are close together.
Peter
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
