Author Topic: Cannot read previous images saved in tiff format  (Read 3103 times)
Offline gvanhau
« on: 2012 June 28 21:54:39 »
Hello
I wanted to read an old image written by pi  in tiff format
but I got a message telling me that there is no installed file format for this image.
I tried with several other images and got same message.
I restarted PI and still the same.
What happened?
Regards
Geert
Geert Vanhauwaert
Re: Cannot read previous images saved in tiff format
« Reply #1 on: 2012 June 29 01:21:59 »
Hi Geert,
Your PixInsight installation has been messed for some reason; your TIFF format support module has been uninstalled. Do the following to reinstall all available modules:
- Run PixInsight.
- Select Process > Modules > Manage Modules from the main menu.
- On the Manage Modules dialog, click the Disable All button, then the Done button.
- Exit PixInsight.
- Run PixInsight.
Now everything should work normally.
Offline gvanhau
« Reply #2 on: 2012 June 29 08:04:33 »
Thanks Juan
I'll try this out.
Regards
Geert
Geert Vanhauwaert
