Author Topic: Super small un-expandable window  (Read 4932 times)
Offline kgav8r
« on: 2007 November 13 11:41:22 »
When I load an image for editing or processing, the window is the proper width, but the height is less than 100 pixels.  When I attempt to resize the image, the overall window size stays the same.  It is as if the top pixels are being cutoff or blocked from view no matter what i do.
-KDG
« Reply #1 on: 2007 November 13 13:17:34 »
Hello, and welcome to PixInsight Forum.
This issue has been reported in a few cases by Windows users. The problem seems to be related to the Windows XP style, and we still haven't found its origin.
Please try selecting a portable style that doesn't use Windows resources, for example the Plastique style (Window > GUI Style > Plastique). This should fix the problem for you.
Let me know if this helps.
Offline kgav8r
Thanks!
« Reply #2 on: 2007 November 14 00:05:06 »
Thanks, that did fix it.
My spanish is not the best, but I was able to find a previous post that related to the same problem and I was able to fix it earlier.  This did correct the issue.
-KDG
