Author Topic: Batch preprocessing script problem  (Read 5181 times)
Offline Bob Hertel
« on: 2012 May 02 15:57:52 »
Hi, all
I tried the script, but no matter what, I keep getting this message: "cannot integrate less than three frames".  Suggestions?
Thank you.
Re: Batch preprocessing script problem
« Reply #1 on: 2012 May 02 16:05:54 »
Hi Bob,
Welcome to PixInsight Forum. You need at least three images selected in each calibration set (bias, darks, flats) because this is the minimum that can be integrated. You need also three or more light frames if you enable the final integration option (it is enabled by default).
Offline Bob Hertel
« Reply #2 on: 2012 May 02 19:02:01 »
Hi, Juan,
Thanks.  I did put in a number of lights,but I used a master dark and a master flat for those sections.  If  you are saying I need to put in the dark and flat subframes, I guess I'm a little surprised, because that means we'd have to recreate the dark and flat masters each time,no?
Bob Hertel
Offline chris_todd
    • I don't have hobbies, I have obsessions...
« Reply #3 on: 2012 May 02 20:11:03 »
If you use masters for the darks, flats, or bias, you need to check the "use master dark"/"use master flat"/"use master bias" check boxes.
Uncooled, unmodified Canon T2i/550D, various lenses, and AstroTrac TT320X-AG
