Author Topic: First try with M42 and PI  (Read 2404 times)
Offline JamieInCLT
    • My Astrobin
« on: 2012 March 03 12:14:01 »
After struggling with what ended up being not enough data (thanks pfile), I at least got through an image that is decent (for me, any way).
I am looking for any steps that I might have missed, or would be better than what I used.
Tech details- about 56 frames, ranging from 3 to 30s each.  Celestron CPC-HD @ f/10, nikon d90 @ iso200 iso100(not on purpose).
Process overview:
  • Remove images with trails, etc.
  • Register all images together
  • Integrate the 30 images with time greater than 20s (windsor sigma, low=4, high=2)
  • Integrate the 26 images with time less than 20s (windsor sigma, low=4, high=2)
  • HDR Composition of the longer and shorter bundles
  • Auto BG extraction
  • Dynamic Crop
  • Histogram Transformation (now non-linear)
  • ACDNR
  • Color Calibration (I still don't get this)
  • Unsharpen Mask
  • Curves Boost the saturation
I still have a lot to learn about PI, but after using the trial I can't see how I could get by with anything else (especially since I use a Mac)
So- what should I have done sooner (or later)?  What should I have done instead, or what did i miss?  Thanks!
« Last Edit: 2012 March 03 12:35:59 by jamiesmithnc »
Offline Lex
  • We do it at night...
Re: First try with M42 and PI
« Reply #1 on: 2012 March 03 12:22:02 »
I think your second try is fine, better than mine!
If you want to avoid to clip faint nebula details i think you should be less restrictive in your background neutralisation. Personally i prefer the dbe tool rather than the auto one.
Try to obtain more layers with hdr wavelets.
Try to get rid of the greenish touch with scnr tool.
Try a heavyier lift of the saturation boost to focus on the core of M42.
This would be the steps that i personally would give a try!
Btw it is a nice result!
Clear Skies!!
Lex
Offline JamieInCLT
    • My Astrobin
« Reply #2 on: 2012 March 03 13:06:30 »
I uploaded a new revision to astrobin
I swapped out the ABE with the DBE, and it is a little nicer.  I forgot about the scnr, so I did that too.
I found out that I actually took these at iso100, not 200 which I thought, which explains why there isn't as much data as I would have thought.
« Last Edit: 2012 March 03 13:12:02 by jamiesmithnc »
« Reply #3 on: 2012 March 03 14:57:47 »
If you'd like to show the sequence of processes that you used you can also right click on the image, choose 'load history explorer' and take a screenshot of that. This looks really nice but my method is a lot easier :)
Offline Lex
« Reply #4 on: 2012 March 07 13:24:29 »
I think your second try is way nicer than the first one!
As you said there is perhaps not enough signal to represent a detailed image...
@ Sander: Indeed your way is really easier, thanks for this info; newer tried that  :)
Clear Skies!!
Lex
