Author Topic: Save All  (Read 22405 times)
Offline Jack Harvey
Save All
« on: 2007 October 23 05:57:12 »
As well as Save and Save as I would like to see a Save ALL so a single click would save all the open images.  Helpful for instance if you have registered the R,G,B against the L and now want to save them all.
Jack Harvey, PTeam Member
Save All
« Reply #1 on: 2007 October 26 02:32:03 »
Good idea, Jack. Count with it for the next version.
However I am a bit concerned about the possibility of making a mistake and selecting Save All instead of Save As, for example. Many times one is simply playing with an image and don't want to save what is being done. Yes, this is bad practice (one should always play with a duplicate of the image, never with the original), but this does happen.
So how about a confirmation message? Something like "Do you really want to save all images?" when the user selects Save All.
Offline Jack Harvey
Yep
« Reply #2 on: 2008 January 05 12:30:47 »
Maybe use "Save All Images" or "Save All Open Images" so it looks different than Save As
Offline ngc1535
Re: Yep (Image Container version of Save All Views)
« Reply #3 on: 2018 January 16 21:15:23 »
 So years  (decade?) later there does not appear to be a "Save All".
However is there a reason why loading a set of views in the Image Container, specifying an output directory and then running No Operation (or the identity Histogram) does not write the views to the directory? I guess the general question is why is it not possible to write views to an output directory. Perhaps I am doing something wrong (could some one confirm?).
Adam
