Author Topic: Colorcalibration  (Read 2885 times)
Offline Herbert_W
Colorcalibration
« on: 2012 February 04 04:32:55 »
I have SDSS colorcalibrated RGB-frames (from THELI) with these factors:
Red 1.385
Green 1
Blue 0,65
In PixInsight > LRGBCombination > Channel Weights  is the highest possible number 1.
How can I use the factors from above for RGBCombination in PixInsight?
Several attempts (subtract 0.385 from G and B, divide by 2 to get numbers < 1, PixelMath; ...)  ended with a horrible colorcast.
I'm afraid, my math problem-solving abilities are not up to date ;-)
Thanks a lot for your help and best regards.
Herbert, Austria
Offline Philip de Louraille
Re: Colorcalibration
« Reply #1 on: 2012 February 04 05:24:32 »
To keep your color *ratios*, you'll need to divide, not subtract.
Divide your R, G, and B values by the highest value you have so it will scale that to 1.
Your highest value is 1.385, so divide R, G, and B with that.
New values, kept to scale:
R = 1
G = 0.722
B = 0.469
Philip de Louraille
Offline Herbert_W
« Reply #2 on: 2012 February 05 08:02:49 »
Hi Philip!
Thank you for your help!
Best regards
Herbert, Austria
