Author Topic: Where to report a Star flare up?  (Read 5595 times)
Offline Cleon_Wells
« on: 2012 January 15 10:27:17 »
Check this image out showing a star flare up in the field of view of my two  ngc7635 images, separated by 101 days, (10/2/11-01/10/12). The changing Low Pixel Rejection maps are from subs that I acquired on 01/10/12. These subs are 120sec with a 5sec separation, I combined the first ten subs and integrated with Region of Interest (Preview Window 01), I then removed the first 4 subs and added the next four subs, keeping the total integration to 10 subs for each of the 11 Integrations.
Cleon
« Last Edit: 2012 January 15 12:52:27 by Cleon_Wells »
Offline martin_magnan
    • Messager Céleste
Re: Where to report a Star flare up?
« Reply #1 on: 2012 January 15 16:27:26 »
Woah !!! nice catch Cleon
Martin
TEC140 / AP1200GTO / QSI583wsg - Astrodon LRGB 2 filters / Lodestar X2 Guider / Robofocus
http://www.messagerceleste.com
Offline Cleon_Wells
« Reply #2 on: 2012 January 15 16:56:55 »
Martin, thanks, this is another example of my skillful use of Dumb Luck Processing. DLP. 8>)
This star/object is visible  in this image taken in 1997.
http://www.frazmtn.com/~bwallis/n7635_ao.html
I assume this is a Nova, a white dwarf star pulling material from the dim visible  companion star in this location.
Cleon
« Last Edit: 2012 January 15 19:42:22 by Cleon_Wells »
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
« Reply #3 on: 2012 January 15 21:47:20 »
Hi Cleon,
I have identified the image area using a DigitizedSkySurvey plate, and later could identify the object with Aladin: seems to be the variable star MO Cassiopeiae, a Mira type (pulsating, long period, high amplitude)
Also, a nice catch ;)
Best regards,
Enzo.
Offline Cleon_Wells
« Reply #4 on: 2012 January 16 04:06:36 »
Enzo, thanks for the identification of this object. I did joke with my wife on the remote possibility that this was an incoming fleet of Destructor Ships. 8)
And I though we were about to hear some poetry from “Prostetnic Vogon Jeltz”
Getting back to my Method of discovery (DLP) and (PI, The Good , The Bad and the ugly).
The Pros of PI are all the adjustments the Cons are the same and the ugly is me.
The Method is Image Integration/Pixel Rejection Maps and DLP. I used a sub from 10/2/11 to Register the 1/10/12 subs and one 10/2/11 sub as my reference sub during Image Integration of the 1/10/12 subs. This combination revealed a round star (MO Cas) in the Low Pixel Rejection Map, with a Low Sigma window setting of 2.5%.
Cleon
« Last Edit: 2012 January 17 07:28:04 by Cleon_Wells »
