Author Topic: LRGBComposition trouble with rotated images  (Read 2783 times)
Offline Fco. Bosch
« on: 2011 December 30 13:09:22 »
I have been using a CCD monochrome camera for the first time, -instead a DSRL- with images adquired in two months (probably also with camera rotation), and I can't compose the LRGB image, because the  rotation of their components. The L set of Images and the RGB three sets are one month away, and altough I have aligned all, the final image is a intersection or crossing of the L and RGB images, and also exist rotation between the RGB sets, for -I think- the delay in their adquisition.
    Exist rotation between the L and RGB images and inside the RGB ones (adquired in diferent times). The image is like this. Can you help me ??!!
    Tanks!
Fco. Bosch
Offline sreilly
Re: LRGBComposition trouble with rotated images
« Reply #1 on: 2011 December 30 13:21:22 »
I'm not sure I follow the question but if asking what to do, I would crop the image after they have been aligned and then combined into the LRGB image. Then process the resulting image as you would normally.
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline Philip de Louraille
« Reply #2 on: 2011 December 30 17:42:03 »
Clearly the only image you're going to be left with is the one within the intersection of all LRGB sets.
Looking at your attachment, I would rotate the current image about 30° toward the right first and then crop to get the biggest area you can. You may have a dark corner or two (can't tell since we do not see the entire image) but those won't affect in further image processing.
Philip de Louraille
