Hello.
I'm new here, so a few words about my person. I appologize for my broken English (I'm from Germany).
About a year ago I started in astrophotography with a cooled CCD-Kamera (ATIK 383L+) with a small refractor. After some inevitable problems, I had to solve, I got some good results. One of the steps to improve my result was switching to PI. I used AstroArt for a while, which is a fine piece of Software, but sometimes gives me not enough possibilities to control the workflow. So I discovered PI and now I'm learning to use it - which is sometimes not easy but PI is definitive worth it.
My workflow is relative simple, I'm taking L(1x1) and rgb(2x2) frames, the processing is very similar to the NGC 1808 video tutorial from Vicent Peris. After some hard learning I get relative good results now, but there is one problem I can't get rid of, when calibrating my images.
First I integrate my darks and bias frames with the settings shown in the first image (nearly the same like in the according master calibration tutorial of Vicent Peris).
Next step is the calibration of the flats (made with ef flatfield foils) as shown in image 2. And here is the problem: About half of the frames to calibrate fail with the warning "No correlation between the master dark and target frames". The frames which succeeds have often very low dark scaling factors like 0.03 ... as far as I understand the process this value should not be too far from 1.0 because I use always darks with the same expose time and temperature (-30), as the according frames.
If I deactivate "optimize" there are no more problems, but I assume, the result is not optimal.
This warning was several times discussed in these forum, but none of the found reasons seems to match here. I think there is no double substraction of bias because of wrong parameters and also my darks, bias and flats look very normal in my humble opinion.
If I don't use flats I get the same problem when calibrating my lights with master bias and master dark.
I also tried this on windows (I'm using the Mac version), this didn't change anything. But I discovered, the results of PI running on OS X are not always exact the same like running on Win7, which seems a bit curious to me.
In the moment I really have no idea what I'm doing wrong, maybe, you can help me?
Regards from cloudy Bavaria ...
anducal
